Hello there guys! I was asked to do coding in HTML and advised me to use Eclipse for it. I was also introduced to Zend Studio since it has a feature of WYSIWYG, it'll be easier to do it. My problem is how to setup Zend Studio Visual HTML in Eclipse, I need your step-by-step process in doing it. Thanks guys!
Help in setting up Zend Studio Visual HTML
In this pdf tutorial on the link below is given detailed explanation how to install Zend Studio for Eclipse as a Set of Plugins. There is all installation procedure that I hope will help you. It is step by step instructions who will guide you for quick and easy installation.
http://static.zend.com/topics/Installing-Studio-v601-Plugins.pdf
I will give you some quick tips: Open Eclipse and install updates. Select the second option, search for new features to install. Click on the right side on New Remote Site and enter in the name Zend Update Site and in the URL. Now in the list choose the update you want and click finish.
Williamson Mellisa
