Help with tool fix gadgets for windows 7?
I’m using Windows 7 64 bit, recently I downloaded new gadgets from internet and now all my gadgets are not functioning properly. Can anybody help me for tool fix gadgets?
Please do the following and get solved the problem you face now:
1.Right-click on the Sidebar icon in the system tray
2. Choose Exit.
3. Close the message you see.
4. Check Task Manager to make sure there are no sidebar.exe processes running that should not run.
5. Restart the Sidebar to Default
6. Open a Windows Explorer window and paste the following message in the location bar:
%localappdata%microsoftWindows Sidebar
7. Here you'll see a file named Setting.ini, Rename the file to something else or at least make a backup of the file elsewhere. Your current configuration file is in it.
8. Re-launch the Sidebar from the Start Menu and you will see a new Setting.ini has been created immediately.
I think your problem has been solved.
Hathy
