Help with TypeError #1009 Cannot access a property
Hi Experts,
I got an error message when I try to run a project in Adobe Flash Player. I have this software in the system for more than a month and I am a beginner in this field. The error states that it cannot access a property or method of a null object. Do I need to reinstall the application again? Please help me to fix the error. Thanks a lot.
Adobe Flash Player 10
TypeError:Error # 1009: Cannot access a property or method of a null object referred
At Drawing 0 [/Users/stallons/Documents/Adobe Flash Builder Beta/refactoring
At_Drawing_mx_managers_SystemManager/create()
At mx.managers::SystemManager/initialize TopLevelWindows() [E:dev/trunk
At mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx
At flesh.events::EventDispatcher/dispatchEventFunction()
