HELP V 4.2.2.19 problem with Vista-64 bit SP1
Hi Pro,
I installed the BW in the computer, I did not face any problem while installation. I thought everything is perfect and I am glad about it. But to my surprise I got this weird error message when I start the application. Where I can find the missing dll? How to fix the dll in desired folder? Please help. Thanks.
BW.exe – Unable To Locate Component
This application has failed to stat because ogg_tag.dll was not found. Re-installing the application may fix this problem.
OK
Answered By 590495 points N/A #185095
Since the name of the program here is very unclear, just make sure its version supports your operating system. You need to check the program’s system requirements to see its supported operating systems. The application’s specifications usually come and included in readme file included in the package and you can normally find it in the application’s installation folder.
If the file is not available there, try visiting the program’s official website and you can check there the specifications. In case your operating system is supported, try reinstalling it. Uninstall it, restart your computer, and install it back. Run it afterwards and see if it works. If you still can’t make it run, try running it as administrator.
Right-click on the program’s shortcut or icon on your desktop and select Properties. Go to Compatibility tab and check “Run as an Administrator”. Click OK and start the program again. See if it works. If it doesn’t, download the latest version.
