HELP : Want to burn movies in DVD
Now i have Nero 7 full version with me and i would like to burn my movies ( .AVI , .MKV , MP4 , FLV ) to a DVD cd.
And it must be playable on Standard DVD player. Seeking help from experts.
I searched all over the internet and cant find the right information on burning movie files with Nero 7.
Thanks in advance.
Best Answer by ivanxhajduk
Answered By 0 points N/A #155797
It 's easy because you are using Nero, just open Nero Express, click at Videos/Pictures (or something same you will see) and you will see DVD video files, click that and ADD your movie. You must check you DVD player for video formats. For example my DVD can run only .AVI movies, so check don't burn DVD without check!
Answered By 5 points N/A #155798
It's very easy, using Nero for burning makes the CD burning process very easy. Just open your Nero. Select Video from the list (Right Side, you can also burn a CD by selecting data). Now Add files by clicking browse button ( on the right bottom). After adding click next then click on burn.
Answered By 5 points N/A #155799
Follow the steps below for burning DVD using your Nero 7:
1. Launch your Nero Vision by double-clicking on the Nero icon on your desktop. Click DVD and select Make DVD-video.
2. Locate the video file that you want to import by clicking on the Add Video file. A pop up window will appear wherein you can find your video files. Press OK to add it to your project.
3. Click the video to highlight it and then click Create Chapters to go to the video and add some chapters. Or click Create Chapters Automatically.
4. Sort your videos and click Next to continue.
5. You can edit your DVD menu. You can also add your own wallpaper, just click on the Import button or icon on the right pane.
6. Change the Title of your DVD. Double-click the menu and then type your new title. You can also customize your text.
7. Double-click on each video and change the display. You can also add a picture and make it your default Play button picture.
8. Click Next to preview your DVD.
9. Place your blank DVD on your DVD drive. Click the Burn icon to start burning. Select the correct speed and remember to close all the active programs to avoid interruption.
10. Wait until it finished. An alert will pop up if the burning process is done and the DVD drive will automatically eject. Get your DVD and try playing it on your DVD player.
