Hewlett Scanner giving tough time..!!!
I am using Hewlett Packard 1100A (Printer, Copier, Scanner) an old version printer. Copier & printer are working absolutely perfect but the scanner is not working. Let me know how to fix the problem?
Usually HP laser doesn’t need any device driver to be installed because it automatically detects and update it.
But if your operating system didn’t retrieve it you can download a driver directly from the internet.
You can have another option of using an HP laser 1100A scanner. You need to install two operating systems on your hard drive. Both operating systems can be installed in a single partition. First is according to printer requirement and another would be of your choice. Remember you can log in to only one operating system at a time.
Now it’s up to your discretion which operating system you want to log into. If you want to scan a document through HP 1100A then log in to windows 98 otherwise log in to another operating system you have installed. If the scanner is still not working then there may be a hardware issue. The scan button at the forehead of the printer must be checked.
