Hey, Can Anyone Tell Me, What Is This 0x0000007e Error?
Hi, Guys! I recently faced a 0x0000007e error message inside my computer. Please tell me, what is that error, and tell me a way to fix it?
A) – This 0x0000007e error means that your OS is damaged and due to which the system is cannot start. It could have caused due to bad sector, virus, malware, or maybe an antispyware program. To fix it, you need to clean reinstall your windows again.
B) – This 0x0000007e error means that your operating system is damaged and due to which the system is unable to start up the system loading sequence. It could be due to hardware issues like damage, improper or loose wiring, etc. To fix it, you need to check if the wires connected properly to the hard disk or reinstall the system once again.
