Hey, Does Anyone Know A Way To Fix This 0x004f063 Error?
Hey, I was trying to activate my windows when I faced this 0x004f063 error. Can anyone tell me how can I fix it?
The 0x004f063 error is a runtime and happens when Windows fails or crashes while it’s running. It does not mean that the code is corrupted, but just that it did not work during its run-time. To fix this problem, you need to stop these conflicting programs.
• Open Task Manager by pressing Ctrl-Alt-Del keys all at the same time. It will show you the list of programs that are currently running.
• Then, go to the Processes tab and stop the programs one by one by highlighting each program and pressing the End Process button.
• You will need to watch if the error message will appear again each time you stop a process.
• Once you get to the main program that is causing the error, you have to go ahead with the next troubleshooting step, reinstalling the application.
B) To fix this 0x004f063 error, you need to reinstall the graphics drivers.
