Hey, Everyone! Can You Fix My Windows Update Error 800f080d?
Hello, everyone. During my windows update, I encountered Windows Update error 800f080d. What does it mean exactly and how can I fix it my problem?
These windows update error 800f080d occurs if Windows Security.dll files are registered incorrectly. To fix this, you need to download and then run the System Update Readiness Tool and install it later with the updates. You will also need to download the Windows Update Troubleshooter and then select Open or Save in the pop-up window. If the pop-up doesn’t show up, you have a pop-up blocker on, and you will need to turn that off.
If you are using some other browser or maybe a separate pop-up blocker, then you will need to check the website of the browser or blocker’s manufacturer. If you have selected the Save option, then you will need to go to the folder where the troubleshooter has been downloaded to and after the download is complete, and then double-click
WindowsUpdate.diagcab file to run the troubleshooter. Click next and follow the steps in the wizard to find and fix problems with Windows Update.
