Hey, Guys! Can Anyone Tell Me What 0x80072efd Windows Update Errors Are?
Hey, today, when I started my computer, I faced this 0x80072efd windows update error. Please help me fix this?
A) The 0x80072efd windows update error means that there might be some corrupted files, or there is some issue with the network or network card that is causing this error. To fix 0x80072efd windows update error, you need to run the windows troubleshooter by following these steps:-
1. Go to the Settings > Update & Security > troubleshoot.
2. Then go to the windows update inside the windows 10 and run troubleshooter on it.
It might solve it.
B) To fix this 0x80072efd windows update error, you need to run the “sfc/scannow” command inside CMD as admin to fix it. This command scans for corrupted files and then replaces them with the fixed one.
Notifications
