Hey, The Solution To 0x8004d00e Error Is Easy! Is It?
Hey, Everyone! I encountered this 0x8004d00e error. Can anyone tell me how to fix 0x8004d00e error and what could have caused it?
Answered By 0 points N/A #342357
0x8004d00e could be caused due to two different versions of all in the GAC (MSIL and x86).
When you check your DEV, you will find that the platform was set to “Any CPU,” which needed to be at x86 because the A & P environments are running in 32 bit. You need to create a new MSI and import it. Then you will not have any issue anymore with starting the application.
