Hey, The Solution To 0x8004def7 Error Is Easy! Is It?
Hello, Everyone! I encountered this 0x8004def7. Can anyone tell me how to fix 0x8004def7 error and what could have caused it?
A) Well, the 0x8004def7 error occurs when there is some sort of problem in signing into your one-drive related account. To fix this error, you need to open the run dialog box by pressing the Windows key and the R key altogether to open the run dialog box, or by typing run in the start menu search area box and then running it. In that type the following: %localappdata%\Microsoft\OneDrive\onedrive.exe /reset. It will fix your problem.
B) To fix this 0x8004def7 error, you need to uninstall and install the one-drive to fix it. It might fix your problem.
