Hey, The Solution To 0x80072efd Windows 10 Store Error Is Easy! Is It?
Hey, Everyone! I encountered this 0x80072efd windows 10 store error. Can anyone help to fix the 0x80072efd windows 10 store error and what could have caused it?
To fix 0x80072efd windows 10 store error, you need to make sure that the date and time are correct on your computer, and if it is showing the incorrect time, you will need to fix it. Then, run the script inside the CMD to re-register the new Store:
· Press the Windows key and the X key altogether and then run CMD as admin.
· In the CMD, type the following command:
PowerShell -ExecutionPolicy Unrestricted -Command “& {$manifest = (Get-AppxPackage Microsoft.WindowsStore).InstallLocation + ‘\AppxManifest.xml’ ; Add-AppxPackage -DisableDevelopmentMode -Register $manifest}”It should solve it.
