Hey, The Solution To 0x80072f0d Windows 10 Store Error Is Easy! Is It?
Hello, Everyone! I encountered this 0x80072f0d Windows 10 store error. Can anyone help fix the 0x80072f0d Windows 10 store error and what could have caused it?
A) Well, the 0x80072f0d Windows 10 store error occurs when the store has some issues like cache, virus, corrupted files, etc. To fix it, you need to enable TLS by following these steps: –
1. Hit and open the Start Menu option in the bottom corner of the screen and then go to Settings.
2. Press on the Network & Internet option and then hit the on the Wi-Fi on the left side and then, on the right side, scroll down and hit on the Internet Options.
3. Then, go to the Advanced options, and then inside the Settings, go to the Security.
4. Tick the Use TLS 1.2 option to enable it.
5. Hit on the Apply button and then smash the OK button.
6. Restart your computer. It might be fixed.
B) To fix this 0x80072f0d Windows 10 store error, you need to update windows by going inside the windows update installing the latest one.
Notifications
