Hey, The Solution To 0x80072f78 0x20000 Is Easy! Is It?
Hey, Everyone! I encountered this 0x80072f78 0x20000 error. Can anyone tell me how to fix 0x80072f78 0x20000 and what could have caused it?
A) 0x80072f78 0x20000 error could be caused due to various reasons. To fix it, you need to follow these steps: –
1. First, you will need to go to C:\Windows\SoftwareDistribution\Download and then delete all files inside that folder.
2. Then, press the Windows key and the X key altogether on the keyboard and then, open CMD as admin
4. Write this command on it, “wuauclt.exe /updatenow” and then hit the Enter key
B) To fix the 0x80072f78 0x20000 error, you need to perform a clean boot and reset your computer to fix it.
