Hi all, Can someone teach me how to disable the administrator.
I have a problem with my Operating System administrator, My Operating System is Windows 7. I don't know to disable my administrator. I cant stall freely.
I hope someone could help me with it.
Many thanks.
Best Answer by Arnold Max
Answered By 0 points N/A #86056
what is your problem about ? its not clear
i think that  you are talking about user account control, in windows there is an option to control the behavior of a user account and that is called UAC ( user account Control ) no matter what user account you use it will prompt you to allow it when you are trying to do a change in your system. this can be also done by a software. but no matter software or a user it will continuously prompt you alerts. for an example think that you have installed JRE ( Java Runtime Environment in your system and when it tried to search for update and when it try to install it you will get notification each and every time if you enable user account control settings
to overcome this problem you can do like below
go to control panel > select users > then click on "Change User Account Control Settings"  it will open window and all you have to do is click and drag slide bar to never notify  status ( drag the slide bar to the bottom )
now you are done  – but i strongly recommend to have a user account control setting in at least minimum level, it will help you to prevent your system from unauthorized system changes
if this is not your problem  please post me a comment . i will reply
thanks
Answered By 0 points N/A #86057
It means that you are not the administrator of that computer and you can't disable it. Someone has to be the administrator. You can ask permission to the computer's administrator to give you rights to install any necessary programs that you need. Probably, give you the administrator right as well.
But in case you are curious to become administrator, you have to go to the Control Panel and the choose User Accounts. From there you can Change Account Type to administrator.
Still you won't be able to do this because you are not the administrator so ask the one who really owns the PC.
