Albert C
Posted on - 10/05/2011
What software should I install for my Windows 7 and what antivirus that should I install?
Many thanks in advance.
Hi to all, I have a problem about software and anti virus.
Hi Albert,
There are quite a lot of antivirus software's that you can buy or download for free to install on your computer. You first have to take into account what type of antivirus are you aiming for, whether it is free or a software that you have to buy. For a free antivirus, the most highly rated would be the Avast Home Edition 6.0. It is fast in installing and scanning without any loss in its efficiency in detecting viruses.
If you plan on buying an antivirus software there are many choices out there and it all comes down to preference. Kaspersky is a good antivirus and right now is one of the top rated software's to buy. Norton is a well known name in the antivirus industry and is also a top rated antivirus though it is a heavy program and can slow down your computer.
Here are some links to help you choose what antivirus to get.
https://www.kaspersky.co.in/downloads
https://www.microsoft.com/en-us/
Regards.
Hamza R
Hello Albert,
I have suggestions for you. I suggest that you just the windows update will Download and install the software's that suitable for your windows. And try to use Microsoft Essential as your antivirus. Or Download and Install the Microsoft Visual Studio 2005 and Higher version of Microsoft Visual Studio.
Make sure that you will install the lower version of Microsoft Visual Studio first and after that the Install the Higher Version Of Microsoft Visual Studio. Also try to explore the software that your windows might be needed.
Just enjoy exploring.
Good luck!
If you need an antivirus on your computer, there are antivirus programs that don’t eat much space. Check the following free antivirus software:
- AVG Free Antivirus – supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10 both 32-bit and 64-bit. It requires Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor with SSE2 support, 1 GB RAM, 2 GB free space, 1024 x 768 minimum screen resolution, and internet connection for downloading updates and program activation.
- Avast Free Antivirus – supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10. It requires Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor with SSE2 support, 1 GB RAM, 2 GB free space, internet connection for product activation and downloading of updates, and 1024 x 768 minimum screen resolution.
- Avira Antivirus – supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10. It requires Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor with SSE2 support, 2 GB RAM, 2 GB free space, and internet connection for product activation and downloading of updates.
