Hi, Everyone! Do You Know What This 0x8e5e0152 Error Is?
To fix this 0x8e5e0152 error, you will need to follow these steps:-
1. Hit the Windows Key and the X altogether on your keyboard and then choose the “Command Prompt (Admin)” from the menu.
2. Now, you will need to write down the following commands at the command prompt. Hit the “ENTER” key after each consecutive command.
net stop wuauserv
net stop cryptSvc
net stop bits
net stop msiserver
3. Now write down the following commands in the Command Prompt. Hit the “ENTER” key after each consecutive command.
ren C:\Windows\SoftwareDistribution SoftwareDistribution.old
ren C:\Windows\System32\catroot2 Catroot2.old
4. Now write down the following commands in the Command Prompt. Hit the “ENTER” key after each consecutive command. net start wuauserv
net start cryptSvc
net start bits
net start msiserver
5. Now close the Command Prompt and then restart the computer.
6. Now, restart the computer.
