Hi, I need tips for an hp media smart webcam 42 setup
Hi, Louise Rios
While goggling you will find a lot of forums, but the chances of getting the right solution depends on where you post your problems. We have so many different forums to set up an hp media smart webcam 42 .
So classifying and posting them on relevant forums is the best way to get your answer step by step.
Hi Louise,
Did you mean HP Media Smart Webcam 4.2?
It is the best choice for you if you want to stream and upload your tutorials. With the newest version, the recorded videos will be saved as MPEG format and automatically imported in the HP MediaSmart Photo and Video Library.
You may download directly the newest version which is 4.2.3303 from HP website:
Before downloading this software, make sure that you met the system requirements.
HP Media Smart Webcam 4.2.3303 is compatible to Windows 7 operating systems only.
1....
