Walter Neff
30 points
Posted on - 10/02/2012
I had a huge problem with how I was logging into my computer. Since I work online, I will need to figure out a way to log in to my computer without any issues in how I get logged in using logmein for Avaya. Can anyone help?
Hi, I need to use LogMeIn for avaya for my computer
I will help you with LogMeIn software is a very popular remote access app. From your pc sign in to your new Logmein account at LogMeIn.com and click Add Computer and then follow the on screen instructions.
Now you've installed the free trial of LogMeIn Pro. This is the beginning. When the trial is expired, you can buy a Pro subscription. You also can continue with LogMeIn Free. Now, leave your home pc on and connected to the Internet.
Then just log in at LogMeIn.com from any pc, find your home computer listed on the Home page and click the Remote Control button.
