floyd
430 points
Posted on - 05/31/2011
My computer run out of the battery even though the charger was plug into it the whole time I am using it. Anyway, that is not the problem since I had an idea that the charger of my laptop is really working weird this days. I am having a hard time connecting it to my laptop, its losing its connection so I have to find a good place for the adaptor to work.
When I open my laptop, the battery icon on my system tray says that I only have 0% left so I need to connect the charger. I can't seem to make the charger work (maybe I need a replacement for this). When it connects, I have to press the power button twice until it opens. I saw a black screen with error like this:
Windows Boot Manager
Status:Â 0xc0000411
Info: A fatal error occurred processing the restoration data.
File:hiberfil.sys
Any information that was not saved before the computer went into hibernation will be lost.
Enter=Continue
It was all in a black screen. This is the first screen that appears upon starting. Even though hitting the Enter key will allow me to continue to my windows screen, this message keeps appearing every time I run out of battery. And all the files or data will be lost when the battery goes empty.
Does anyone here knows the meaning of this error?
And how can I fix it to stop appearing and normally start my system even if it runs out of battery.
Please help. My laptop is a Toshiba Satellite A200 with Windows Vista with 64-Bit OS.
Regards and Thanks.
Hibernation Problem on Toshiba A200 Laptop
Hi Floyd's
Hibernation in computer is a management mode that conserves power by powering down the system into sleep mode. In hibernate mode the computer current state is saved to the hard drive but all data will be read upon restoring the power.
Here's how to prevent this problem inhibiting your computer from data loss in Hibernate mode.
Follow these steps and hope this will help.
  Click Start Button, click control panel, click system and security, and then clicking power options.
  On the Select a power plan page, click Change plan settings next to the selected plan.
  On the Change settings for the plan page, click Change advanced power settings.
  On the Advanced settings tab, double-click Sleep, double-click Sleep after, and then do one of the following:
    click On battery or Plugged in (or both), click the arrow, and then click Never.
  Double-click Hibernate after, and then do one of the following:
If you also want the display to stay turned on, double-click Display, double-click Turn off display after, and then do one of the following:
If you're using a laptop, click On battery or Plugged in (or both), click the arrow, and then click Never.
Click OK, and then click Save changes.
Please let me know if this help you.
syfy_tech
floyd
430 points
Thanks for your help.Â
Actually I already tried this step before but still didn't resolve the issue. I found out that the battery and the connector of the adaptor from laptop to wall is broke.Â
I already changed a new one and everything is working well now.Â
Thanks a lot though.
