Hide applications in gis software
I want to hide some applications about geographic in gis software. What option has permission to hide or make password on applications in gis software?
Hi Jamin,
I believe there is no option for you to hide some applications in the GIS Software. In order this applications not to appear in the final output, it should be edited first before saving and publishing the output. You could also save another file to allow you to have the complete/edited version and the original one.
There will be many functions available in the menu bar. You can change the way the GIS looks by moving or hiding toolbars.
You can hide or show toolbars by follow these instructions:
· Click ‘Customize’ on the menu bar> ‘Toolbars’ and check or uncheck the name.
When every time you will use GIS, any changes made will be kept and applied. Some toolbars will be visible, but you cannot access the functionality if they do not hold the required license because some toolbars are approved the license level.
