Hide controls for display on small screens
Hi friends
Iam using Samsung Notebook, as the screen is very small, i would like to hide controls and toolbars as its taking much space on the screen.
Can anyone help me to hide the controls and toolbars in Mozilla Firefox?
Thanks
Answered By 10 points N/A #108175
It’s very easy to remove toolbar. Just use full screen option for doing this. Press F11 button for doing this. If your F11 button does not work, then press Fn+F11 button together. It’s a shortcut of getting full screen mode. You can use this shortcut to get full screen view of any software. To get back again in previous look, repeat the same thing again. Press F11/Fn+F11. You will get back your previous look. This shortcut will works in any program. You can hide your windows toolbar to get more space. Just right click on windows toolbar & go to properties. Check the box “Auto hide toolbar” I think your problem will be solved
