Hide IP, change STATIC and Dynamic IP’s
Hi!
Many software can be utilized for the purpose of hiding the IP address that you are using and will keep your PC and your transactions secured from haughty intruders that could get into your PC accidentally or intentionally. Anyway, one of the suggested software that I’ve tried and it worked just fine is to download Tor.
Free software that you can get or download – It can save you from constant worries of being tracked and detected on your web activities. It works with Windows, Mac and Android. However, you may also tend to use software that can be purchased over the internet. I haven’t tried one since they are really expensive.
You may try one of those, I hope it gave you some idea.
There are a couple of softwares that can provide you with the wanted result, but I'll suggest a single software, because I have tested it earlier and it has proven really great.
This software is named Hide my IP (5.3 is the latest version). This software is compatible with all browsers such as Internet Explorer, Mozilla Firefox, Netscape, Opera, Internet Explorer and many more. One distinctive advantage is that Hide my IP 5.5 is very easy to use and much more compatible than the other similar softwares.
It has the very best characteristics and best features, for example, it is easy to install, can block intruders, allows a fast and easy internet surfing, supports advanced applications, easy email sending and allows unbanned website access. It works rather simply. After you install it on your computer it will adjust your Internet Connection Settings, making your computer to make connections through a fake IP relay provided by Hide My IP.
You can download it here: https://www.hide-my-ip.com/
I whole heartedly suggest you use this software, I am absolutely sure you won't regret it.
Hi there.
The easiest way to hide your IP address is to use a proxy server in one form or another. A proxy is a computer that offers a computer network service to allow clients to make indirect network connections to other network services. The process usually goes like this: a client connects to the proxy server, and after wards requests a connection, file, or other.
The proxy then provides the resources by serving it from a cache or by connecting to a specified server. If this sounds too complicated, you might want to try a more direct approach. Turn off your modem for five minutes and it should change your IP address. It is possible though that this won't be a case, you'll have to turn off your modem for 8 hours and that should do the trick.
Hope this was help full.
Notifications
