High Price of Vaio 13.1” Z Series Customizable Laptop high
The starting price of Sony Vaio13.1” Z Series Customizable Laptop is $2049.99. Isn’t it too high? Are they thinking of doing some less?
Sony sells the VAIO 13.1” Z Series Customizable Laptop at a starting price $1549.99 only. The estimated ship date is 7 days after placing your order. You can adjust the price based on the specs you want. You will have choices of processors, operating system, docking station, hard drive/solid state drive, memory size, wireless mobile broadband and battery. You can have the following specs for the lowest price of $1549.99:
Processor: Intel Core ™ i5-2450M (2.50 GHz / 3.10 GHz with Turbo Boost).
Operating System: Genuine Windows ® 7 Home Premium 64-bit.
Display: 13.1” LED backlit Full HD (1920 x 1080).
Docking Station: Power Media Dock ™ HD 6650M (1 GB) graphics and CD/DVD player/burner.
Solid State Drive: 128 GB (64 GB x 2) with RAID 0.
Memory: 4 GB (2 GB x 2 fixed on-board) DDR3-SDRAM-1333.
No wireless mobile broadband.
Battery: Internal lithium polymer battery (4000mAh).
Additional fees are needed if you will change these technical specifications.
