High Tech Cafe Lights And Sounds
What would I need if I want a system that would make lights and sounds in my cafe controlled by a single computer? Do i need another computer for security cameras?
All you need is an intermediate device that will connect all the lights and sound system to your system.
I do not remember the name of the device but it is available anywhere all over the world.
Actually what the device do is that it allows you to set a rhythm of the lights with the sound and so creating a format of the lights that will be great of the people in the cafe.
After that all you have to do is to activate the song on the system or the computer and the rest of the work is done by that device. Only if you know the device name then it’s a piece of cake for you.
