Highlight the distinctions of Microsoft Dual USB Charger
What is the dimension available of Nokia Dual USB Charger? Which material is used to develop? What are the connectivities available in Nokia Dual USB Charger? What are the charger input and output current need? What is the charger input, output voltage need? Is there an LED indicator available? Thank You
Answered By 0 points N/A #172543
Hello Terry!
Answer – 15.3 x 7 x 3.8 cm and weighing 132 g
Which material used to develop Dual USB?
Answer – stainless steel, copper, zinc, aluminum, Glass, other ceramics, ABS/PC, PET, PA, epoxy, silicon and glues.
What are the other connectivity available for Dual USB?
Answer – micro-USB, Nokia 2 mm power connector, USB charging cables.
What are the charger input and output? Voltage?
Answer – 1200 mA input current, 1000 mA output current, 12-24 V DC input voltage, 5 V output voltage, and 2000 mA output power.
Is there an LED Indicator?
Answer – Yes
