Highlight on WinOptimizer 11 and its necessity
Can it do full scan or quick scan according to system need? Can I erase hard drive partition? Can this fix or repair common Windows errors without removing any file or folder? Which operating system is needed to set this up? Can WinOptimizer show me the real time of RAM and CPU usage? Can I retrieve deleted files and manage internet settings by using this software? What is Ashampoo and how does this work? Can this software recover hard disk crash? Thank You
Answered By 5 points N/A #172390
WinOptimizer is a program that optimizes Windows for better performance and stability. It’s super cool with tons of tools to make the Windows OS even better.
Windows comes with many junk files, default tweaks that makes the performance slower. But if those are tweaked and optimized, the system will performance better. In this case, WinOptimizer does the perfect job.
It cleans unwanted junk files from your system, making the system lighter and run faster. It also optimizes Windows registries, checks HDD health and system to make Windows without any error.
You can also customize hidden settings of Windows to make your system more efficient and customized.
There are also other tools like Game Booster, Rights Manager that enables a robust performance and usability.
You can get WinOptimizer from here.
