Highly recommended Vegas 8 mpg video codec
Hello guys! I currently have a video to convert here to mpg. I want to make sure it is converted without any damage to the video. I want to ask for the most downloaded Vegas 8 mpg video codec converter. THanks!
Best Answer by Hock Clotildec
Answered By 5 points N/A #148351
Hi Centic,
You can download and install various useful and demanding plug ins from the link below in order to convert your video to mpg and other formats.
http://www.fileguru.com/apps/plugin_sony_vegas_8_mpeg
I believe AnyMP4 MXF Converter 6.1.02 software listed on the link would cater to your requirement however you can see for yourself the various applications and its relevance to your task.
Hope this helps.
Thanks
Baker
Answered By 0 points N/A #148352
Hello
There are many applications for converting video to mpeg.
My opinion any-video-converter is the best application when compared with Vegas 8 mpeg video code converter.
Vegas 8 mpeg video code converter has compatibility issues it required additional plug-in. So better go with any-video-converter.
You can download any-video-converter from the official website and it cost $44.95 .
http://www.any-video-converter.com/mpeg-converter.php
Or
You can go for online converters at this link:
http://media-convert.com/
Hope you got some need full from above post.
Regards
Hock Clotildec.
