Highly used software for Ubuntu tiff scan converter
Hi guys!
I have some Ubuntu Tiff scan here and I want to convert them to jpeg.
Any suggestions of Software's for Ubuntu to convert these Tiff scans?
Thank you in advance guys!
Hi guys!
Hi there,
You can download and install the following patch (Photo Batch Processor) software in order to convert your TIFF images to JPEG format.
Following in the link.
In fact this application would be able to convert any format to JPEG or PDF.
You can use simple methods of drag and drop feature to get your images converted.
Hope this helps.
Thanks
Baker
Recommend that you go to this website:
You can read it for some tips on how to convert the stuff in Ubuntu TIFF format into JPEG format.
It has been my pleasure to help you.
I hope you are having a good day.
