Hi Everyone!
I just have a simple query about Windows 7. Anyone here who can teach me where to find the history of downloaded images that I have viewed while browsing the internet? Is there a hidden folder somewhere, where I can see those images? Please help me figure this out. Thank you all!
History of Viewed Images in Windows 7
Hello Conan Herrera,
You can view these images on the browsing history. It also depends on the web browser that you are using. If you used google chrome, on the upper right part of the window you would see a picture of a wrench. Just click on it and a window with options would appear. On the options you would see new tab, new window and at the middle part is history. You just need to click on history and you would be able to view a previous page that contains those images. Another way of accessing it is by pressing ctrl button and h at the same time, it would automatically load the browsing history. This is also applicable on internet explorer.
Atanasosk Pelayo
