Hitman pro cannot be opened after installation
Hello experts,
I just installed on my Windows 8 Hit man Pro and this error appears every time I want to open the program. During the installation I didn’t have any errors but still this error appears. Can anyone help me please to fix this error ?
Thank you !
The exception unknown software exception (0xc0000417) occurred in the application at location 0x010fd7b4.
Answered By 590495 points N/A #180244
HitmanPro is a second opinion malware scanner that is used in conjunction with another antivirus. So, for example, if you have Kaspersky antivirus or Norton Internet Security, you can install HitmanPro to help your antivirus protect your system. HitmanPro encountered an application error probably because of incompatibility or insufficient privileges. Since you are using Windows 8 or maybe Windows 8.1, make sure the one you are using supports your operating system.
To make sure HitmanPro supports your operating system, download and install HitmanPro 3. It requires Windows 2003, Windows 2008, Windows XP, Windows Vista, Windows 7, and Windows 8. When downloading, make sure you select the appropriate version for your operating system because it is available in 32-bit and 64-bit versions. Try it again after the installation.
This version will give you 30 days of free usage.
