How do i make word document to eBook?
For you to be able to make a blog word document to your eBook, you will need to do the following:
-Thompson Locker
There are many third party applications that you can use to convert your doc file to an ebook file. One of it is the Primo PDF. It is free software that can convert your doc file into an ebook. Download it and install from here. Once installed, open your doc file that you want to convert. Double-check f there is no more corrections in your file.
And then save it and then go to File>Print in your taskbar. Primo PDF has been added to your list of Printer options. Select it as your printer and then click OK. A new window will appear with screen, print or custom format options. Choose custom and then select ebook and then click OK.
Below is another option wherein you can edit a location for your new ebook to be saved after conversion.
And you are done.
