Holdem Manager 2 installation not found
Hi there,
I have downloaded the trial version of Holdem Manager 2 and the installer is not working because of this error. I downloaded many time the installer hoping that will solve the error. No result I am still stuck with it. Please can anyone help me fixing this error? Does anyone else had this?
Thanks!
Holdem Manager Setup
Holdem Manager 2 installation not found, please run full installer.
You will be redirected to Holdem Manager Website where you can download this.
OK Cancel
Answered By 590495 points N/A #170178
If you already reinstalled the game Holdem Manager 2 then you should check if the free trial days are over because when you install the free trial version, it has only 30 days to fully function and after that either uninstall the game or purchase it for the full version. Holdem Manager 2 supports Windows XP Service Pack 3 and higher running on the latest Service Packs.
The game will also not work without Microsoft .NET Framework so you better check if you have this on your computer. If you don’t, download Microsoft .NET Framework 4.5.1. If you have problems downloading or installing using this web installer, you can download Microsoft .NET Framework 4.5.1 Offline Installer. These are the same installer but the offline version allows you to save the entire Microsoft .NET Framework installer on your hard drive.
If you are on Windows Vista, you should update to Service Pack 2 to use this version. Visit Windows Vista Service Pack 2 Standalone [KB948465]. But before you can upgrade to Service Pack 2, you must already be running on Service Pack 1. In case all requirements are fulfilled and the game still doesn’t work, you must purchase the Pro version $99.99, Small Stakes version $59.99, or the Pro Combo 2 $159.99. Visit Holdem Manager 2 to purchase the poker game.
