I think this error that I have encountered has something to do with the Holdem Manager software that I just installed. Do I need to update this? Or do I need to download a new software that is like this? What seems to be the problem? Any quick fix for this problem?
Holdem Manager
Error occurred in Update Display: value was either too large or too small for an Int32.
Holdem Manager is not opening
Greetings,
It's unfortunate you ran into this problem with Holdem Manager. It's seems to me like a problem with the HUD or the interface. Can you try this for me? Go to Hud Options, then Player Preferences. Choose your active Hud COnfiguration, tick Scale font. You can create as many HUDs as you like and customize these HUDs different, making it easier to layout.
Hi Calvin,
You may want to check the recent changes you made on your PC before this happened. Â Usually, a System Restore on your PC would do the trick. Go to Start > All Programs > Accessories > System Tools > Â System Restore then try restoring the PC to an earlier time that Holdem Manager worked. Â
If this does not work, you may want to try and check if you have any viruses or Malware on your PC.
You may use one of the free antivirus software here.
