The problem is that my default home page continues to change from my own settings. This started after the site I was once locked up.
I have run the updated ad-aware, spy-bot and Norton anti virus but still no changes.
Yohan
Home page settings changes automatically
Hi James Franklin ,
Your problem is easy to be resolved Follow my steps carefully and we will resolve this problem together what you have to do is
change your Home page to google.com for example then restart your computer if you have the same problem than
the problem is a spy ware that change your home page automatically to an other website so you have to install an Anti spyware then analyze your pc to check for spyware after you finish restart your computer go to your Internet Settings and change home page then restart your navigator and problem 100% will be resolved
You can see if your browser is hijacked when your homepage is changed, tabs or window suddenly pop up, you are being redirected to another site and other unusual browser activity that is not normal to see.
If this happen, do not waste your time closing tabs, windows that keep on popping. Follow the guide below on how to deal with this:
End the browser process. If you cannot control anymore your browser you just need to kill its process by going to Task Manager. Press ctrl+at+delete. If you are using Internet Explorer, locate ieexplorer.exe and just click the “End Process"
Disable the Pop-up on your browser.
Disable malicious software plug-In in your browser.
Run a good anti virus or anti Spyware like Spyware Doctor.
Go to programs installed in your computer and remove unfamiliar applications that has been recently installed in your computer.
