My iPhone is rebooting from 5 to 10 minutes so I put it on Recovery Mode when this error appeared. My warranty certificate expired and I cannot use and also I think that the cost of reparations is pretty high. Is there a way to fix this error? Can I repair my iPhone by myself?
Thank you experts!
The iPhone “iPhone” could not be restored. An unknown error occurred (13).
points
Horrible iTunes error! Please help!
You might be using an older version of iTunes so this issue is arising. Before doing such tasks, you’ll need to be sure that your iTunes is of the latest version. Download latest iTunes.
Another possibility is, your PC is lacking of required disk space so that the software can’t extract or backup files to save.
Try to clean your PC with any good PC cleaner to swipe away junk files. Use Wise Disk Cleaner, CCleaner etc.
The best way to solve your issue is to complete the task with other PC and then re-synchronize the phone with your own PC and restore the iPhone using the last valid backup.
