Host Process Rundll32 Has Stopped Working
Rundll is a program used to load and run 32-bit DLL files.
The Rundll32 error could be due to the malfunction of your PC, so it is not always possible to pinpoint the cause of the error. Most of the time error could either be caused by corrupt registry file or malware disguised as this file.
Solutions for you to try-
– Uninstall the program that you’ve installed just before the problem started.
– Run and scan your PC using antivirus and delete any infected file that you find.
– Use a repair tool to fix the issue and optimize the device.
– Run SCF scan tool, it’ll find and repair all the incorrect registry files.
Reboot the PC after this Scan.
Notifications
