Hosting A Website At Home: Way To Do It.
I have my own business, but it is at a small level. So rather than buying a service of web hosting, I would like to create my own. What are the steps for hosting a website at home?
Step 1: Download Apache HTTP Server which has a public license.
Step 2: To install the file, double click on it.
Step 3: In the next dialogue box, from options select custom install and change the directory of Apache to the folder you want.
Step 4: Find the "conf" folder in that directory and open "https.conf" file. Create a root directory on the Web Server.
Step 5: Change the Apache default serving document root to your web root inside the "httpd.conf".
Step 6: Also change the Apache directory to the own web directory.Â
Step 7: Create a test page using HTML code.Â
Step 8: Open the port 80. /kjy54
Step 9: After opening the browser on the Web Server, type http://localhost/ Your winner page in the address bar.
Step 10: Type http://IP of home/
Method 2-
Step 1: Requirements is high-speed connection.
Step 2: For your home, the internet connection gets a hostname and also a static local UP address.
Step 3: Correctly make connections on port 80 to your web server by configuring a router.
Step 4: Communicate on port 80 by configuring Windows Firewall through your web server.
Step 5: Test your web server from your computer after getting Apache.
Step 6: Replace the default home page with your web page.
