Hosting a website into particular domain
Hi everyone
How do i host a php/mysql developed website into a particular domain? I have domain in one site and hosting space on the other.
thanks
Hi everyone
thanks
Hi Antonio,
Read the bellows instruction for add your domain in a hosting :
At first you should have a particular domain name.
Open your hosting cPanel and then log in there by entering your own username and password.
Then select first “Domain Manager” and then select “Add domain”
Now write your domain name and do the next process.
Open your domain cPanel by entering your username and password and then select DNS management.
Then add your hosting server in your DNS setting option. It may need 24- 48 hours time for adjust domain with hosting.
After configure successfully you should upload your PHP files in File Manager area in hosting. You should create a database too in hosting cPanel for sql service.
Thanks
