Hot Spot Management Software windows base
I would like to ask, what are the best hot spot management software, particularly windows base.
Thanks in advance, more power to TechyV
Salvador
Salvador
Hey Salvadorjr,
Hello pal, managing my wifi – hotspot was a big pain for me until I came across an application called Connectify me, it is a windows based software as you are looking for. It is an easy to use software router which utilizes our PC's in-built  wifi (Which usually all Laptops, notepads or ultra books have but very rarely we find them on desktops). You can download the software from below link.
 Hello, Salvadorjr
Hope you are fine. Hotspotsystem.com is the most versatile hotspotsystem available.
You won't require any computer as this software runs on the WiFi router itself!.
It's quick and easy and is for free Hotspotsystem.
On this site you will find a comparison list to compare yourself.
Hope you will get your answer.
