I want to create a Hotspot using my phone which supports to create Hotspot. First time when I tried to create this it worked just fine and this is for the first time when this error. Can anyone help me please to fix this error ?
Thank you !
Hotspot Error
Unable to connect to data network, turning off Hotspot. Your plan may not have the Hotspot service, please contact your phone company.
OK
de Blair
10 points
Hotspot cannot create a connection due to network error
WI-Fi Hot Spotting or Tethering, generally, is not a free service. You should have a working data plan for availing this facility. You need to enable this service on your associating sprint billing account.
One more scenario which is seen responsible for producing this error is not activating roaming while going into roaming area.
Well to overcome this, try:
For rooted android devices, the easiest way is to install a WI-Fi hotspot.Apk file. But this option is limited to a real techy.
Lots of devices allow tethering via Bluetooth/USB only (E.g. HTC smartphones).
Best solution yet found by most of the people is using a third party tethering application. E.g “FoxFi“, which is one of the highest rated application by users. This is a best possible solution for non-rooted phones of naïve users. Moreover, FoxFi data usage includes under your existing data plan.
