The Hovernote application compatibility in Android OS
Hi everybody, I came across new application for Android tablet called Hovernote. Is this application can be used in Android phone instead of tablet?
Hovernote is a skimming notepad application for your mobile device or tablet. With hovernote, you are able to compose short, makeshift notes while utilizing whatever possible application on your unit.
hovernote permits you to open any number of note windows, for unrestricted gainfulness. hovernote's minimalist interface keeps out of your method–a tap of the inquiry catch conceals the window controls, leaving more screen space for your application.
Offer notes to alternate provisions, or impart from different provisions to hovernote! By imparting to Dropbox or different comparable applications, you are able to recovery your notes. You are able to likewise now perused and compose message indexes.
Hovernote is a “floating” notepad application for Android that allows you to write text notes over other running applications without switching out from them. This Android application lets you experience what it is like doing multitasking operations on Android Smartphones. You can compose your notes while your mobile browser is open, PDF viewer, or any other applications.
Hovernote can read and write .txt files on your Android device that features effortless autosaving abilities and sharing of notes to other applications. It also supports Dropbox Sync. You can also use the application to generate its own filename using the present time if you didn’t give any filename when saving.
Download and install Hovernote 2.0.4 on your Android device. It requires Android 2.2 and higher. In this version, you can now remove notes from the Recent Notes list via long-pressing. The application also allows you to open unlimited notes simultaneously.
