The Hovernote application on earlier version of Android OS
Hovernote is a coasting notepad application for your telephone or tablet. With Hovernote, you could probably compose short, makeshift notes while utilizing any viable application on your apparatus. Hovernote permits you to open any number of note windows, for unrestricted profit. Hovernote's minimalist interface keeps out of your method–a tap of the inquiry catch shrouds the window controls, leaving more screen space for your application.
Impart notes to alternate provisions, or impart from different requisitions to Hovernote! By offering to Dropbox or different comparable applications, you are able to recovery your notes. You are able to additionally now perused and compose message indexes.
Hovernote app works with Android 2.3.3 and all the later versions.
Hovernote is an Android application that lets you take quick notes without switching between windows on your tablet. With this application you can take simple notes inside other application. It floats on top of other applications so you wouldn’t have to switch between open applications and taking quick notes is just very simple. This application can be used on any versions of Android. Which means even if you are using earlier versions of Android, you will still be able to use it.
Check out some of Hovernote’s features:
If you wish to download Hovernote, you can get it and see also Take quick notes on your Android tablet with Hovernote for other important information that you might be interested.
