Hi Experts,
I am having Asus connection manager on my Asus laptop. I want to access the Asus connection manager utility to adjust settings. Can expert tell me how get access to Asus connection manager utility. I need complete step by step procedure for this task.
Thank you.
Best Regards,
Omarionalejandro
How to access the Asus connection manager utility?
You did not provide the full name of the utility software. You want to use it for what purpose? LAN or WiFi or 3G.
If you are not sure about the purpose of this software, then use Connection Manager lite.
It is very much uncomplicated to use and discovers any network connection automatically.
What kind of software do you want to use? You didn't explain anything about the name of your software. Do you want to use it for WAN or LAN or another type of network? If you tell me, then I can help you. But now in this case you can use Connection Manager lite. This is fast and very easy to use.
Let me know about your software.
