How To Access Business Objects Central Management Console?
I want to access the business objects central management console. That is being used for managing the business objects that can be grouped and stored in a common well-organised location.
Users, groups, folders, and categories are brought about using BOXI's administrative application, the CMC, which can be opened via the MyEd gateway.
Only Delegated Managers can access the CMC which requires requesting that IS Applications Division places your user account into the appropriate Delegated Managers group.
Managers should log in using their BOXI username and password. Once logged in you would be accessible with the core menu pane.
