How to access to domain account
If I can set up a new domain account within Active Directory and then access to a workstation with this account, what authorization should I give, to the user, by default, or the workstation?
What kind of system are you using may I know the details. There are many ways. The user must be given access to the directory and the files are to be read only permissions. The write function is quite problematic if any one uses it.. Make the group you’re own and the user gets read, list the directory, and execute documents. The Permission for ALL needs to be read. That is all the users maintain a queue in the listings of the group who can share information but not modify along with the execute option. The all others just read the files. Your own shall have dull control to it. Thanks.
