Hi Experts,
I am an IT student and is needed tom access iWay XML Transformation Engine online. I tried to access it but my proxy settings do not allow me. Can you tell me how to adjust my network settings? Thanks.
Jaylonomarion
How to access iway xml transformation engine ?
Hello!
Maybe the problem is not with your proxy. Some sites are not available in some countries.
Another problem could be some program's firewall is preventing you from accessing that site (e.g.) your anti-virus.
Try turning off that firewall.
Talking about Firewall, your OS firewall can be another issue.
If you really wanted to visit this site, try closing your OS firewall.
Warning! Take this at your own risk!
I hope I helped a little. Thank you,
