Hi guys. I have a PC that has Intel Core i3, 2 GB RAM, 1 GB Graphics Card and Windows OS XP 64 bit. I have been using Eudora that includes the MAPI server for my email and messaging needs. How do I access MAPI from command line? Thanks in advance.
How to access Mapi from command line?
Hi Horace,
Opening MAPI from the command line lets you open a specific folder. It opens in a cascading manner where in the folder should be in the same folder from the tree.
If you want to access your mailbox then the folders under your mailbox folder can be open using the command line for MAPI.
You can follow these set of syntax:
For Calendar folder:
Outlook.exe/select outlook:calendar
Open MyMail folder:
Outlook.exe/select outlook:MyMail
If you want to know more click the link here.
