How to access port forward checker windows 7
Hello guys. Any one tried port forward checker windows 7 ? i just cannot get port forwarding to work in windows. Please help on how to check it. I'm looking forward with that matter.
Hello Elias,
Port forwarding occurs in your router, this is when you open specific ports so that access to certain programs or applications are not blocked by your router.
Here is a good guide for port forwarding. Please remember to setup a static IP address so that when you restart your computer the ports are still forwarded to the IP address that you will be using.
Sincerely,
Luz M Terry
Hi Elias,
Good day!!
A. Go to the Start menu and type command in the box.
B. Then right-click on Command Prompt and click Run as administrator.
C. If a User Account Control window pops up, click Continue.
D. Type in ipconfig /all and press enter.
Sincerely,
Lorraine P Goodman
